leaking 03 DRZ 110
Picked up a 2003 DRZ 110 to fix up so that I can say i did 🙂
I cleaned the carb and it did run but of course will have to play with adjustments to get it truly right, but I also did notice the carb did over flow with gas but i am positive that all the parts were not in it from the last owners attempt to clean it haha
Anyway my main concern is a leaking clutch cover and its not coming from the gasket. I attached a picture to show where it is coming from.
My questions are:
Can I take the cover off and just put JB weld on the inside of the cover to patch the leak or just get a new cover ether way i don't loose just want to see if the JB works and if anyone has done it?
Also, I did change the oil and filter so if I just lay the bike on its side I should be able to that the cover off without draining the oil?
Last question is can you guys share a link or let me know what parts the DRZ 110 shares? I have a DRZ400SM and or course know everything about that model and its shared parts I am just wondering if its the same for the 110.
Thanks
Edited by gixxer53
  • 4 weeks later...
