Machine shop recomendation for cylinder bore and head mill in SE Massachusetts
Anyone located in SE Massachusetts that can recommend a machine shop where I can have the cylinder off a 2000 Suzuki JR50 bored and the head milled?  I've called a couple local machine shops and they are either not set up for a small bore (42mm) or not interested in such a small job.  Any recommendations appreciated.
  • 1 month later...
I sent the factory cylinder and head to Don Holubik at Precision Cycle, Inc in Orlando, FL.  I just used USPS Priority One and the cost was just $12.95 each way.  Don charged $60 for the bore and $40 to mill the head.  His bore was spot on for the Wiseco piston.  I've since found a machine shop a little closer to home, but he's still charging about the same for the same scope of work (I'm doing a KTM 300 EXC right now).  Don did excellent work and turned the job the same day he received the parts.  His address is 617 Silverton Street, Orlando, FL 32808  (407) 298-5800.  Good Luck
