110 zstar automatic (Logan/loncin)
Ok so after going over this little atv for my daughter I rode it around a bit and once it warms up it wants to stall. I put it back in the shop after without even looking at it and being late fall in Canada it's pretty chilly. I would assume I have it running to lean atm but any other suggestions for what to look at would be appreciated.
Make sure there are no air leaks at the intake/head or the carb/intake area, leaning it out even more.
You might also need to go up a size on the pilot and/or main jet, for the winter.
I should have mentioned there is an air leak between the intake manifold and the head I know I need to address already and it is jetted appropriately I just have the fuel turned in to far right now because it was still warm when I bought it and started working on it.
