NEED HELP AGAIN SORRY GUYS IM NEW HERE!
Hey so here is my problem, I have a kx250.. I put back together with all the running gears.. I used c clamps to put the case back together. When I put the 2 halfs back together and start putting the screws in and tighten near the chain gear. and the transmission locks up and the crank shaft gets really tight.. Any ideas what it could be?
something is not right in there.
the cases should slide together without the use of c clamps, at the very most a few tap's with a dead blow or rubber mallet....and lightly.
follow the manual and make sure everything is where and how it is supposed to be.
Edited by Excitable
