Headlight on 15 350xcf?
It would be quite easy due to the battery and would require nothing less then running a set of wires from the battery to the headlight.
I run an TT Extreme Race light that has a set of wires that are mounted to the terminals and then ran along the frame to the front of the bike. The light is then mounted to the forks, plugged into the wire and vola, you have lights...
Obviously you could get more complicated or simpler such as a different lighting setups, handlebar on/off switches, dimmers, etc etc...
Edited by Monk
