bearing for ohlins upper shock
hi guys this weekend i have been replacing all the bearings on my bike and when i got to my upper shock bearing i found out it wasn't the same as the stock bearing for the wp shock.
the shock is a kt993 i believe, its a pds ktm. which bearing to i have to buy basically any help much appreciated.
thanks in advance
Edited by tumbiri
Thanks man do you know where is my best bet to get on of these? Ohlins dealer? I've googled it and I've found some site form Norway and I'm not sure if it's the part or anything not that I expect you to understand Norsk or what ever they speak thanks again
http://www.online-mc.no/Fjaering/hlins(9)/Reservedeler(100)/Ball-joint-dia-14-26-15-(00536-13)
It sounds right ish...
Edited by tumbiri
there is no UK service center for Ohlins. At least not according to their dealer list. https://www.ohlins.eu/en/motorcycle/dealer/
You can try the service center in Dublin, Ireland
or buy from the Ohlins Europe Headquater in Germany
or i (from Germany) can ship it to you. I have the bearing in stock.
Just if you need the spacers as well i'd have to order them.
  • 7 months later...
Working on a pair of Ohlins for a Maico rebuild.  Bottom rubber bushings fell apart and got replacement spherical bushings/bearings from WER.  Tried freezing the bearings/heating the shock where they reside, but no luck...too tight.
Don't have a press - was going to use vice/sockets...thought freeze/cool would make for a fairly easy job - any suggestions for DYI, or is this a machine shop job?
Thx!
