Radiator fluid
If you used it, the Peak "Sierra" is the same exact thing as Engine Ice but about 25% the cost. 75% cheaper, in other words. Engine Ice is simply 50% Propylene Glycol with 50% distilled water. I think you can make 2gallons of Sierra with DW at 50/50 for about the cost of one of those tiny bottles of Engine Ice.
Edited by Eddie8v
  • 2 weeks later...
Distilled water is the key. I run it with anti corrosion/water pump lube with no glycol at all. But it doesn't freeze in CA where Im at.
Yes.  Distilled plus water pump conditioner with a couple capfuls of Water Wetter.  No need for ant-freeze unless very low temps.
