2014 YZ 250f gas cap stick/or leak
I've got about 60 hours on my 14 now and my gas cap is getting really hard to remove.  If you tighten it enough not to leak, it doesn't want to break loose at the next fill.  I tried not tightening it as much and then it leaks.  The threads are good and so is the rubber gasket.  Is anyone else having this problem?
  • 2 weeks later...
