WP 4CS fork oil level adjustment
I just bought a new KTM with the 4cs forks.. ive read the articles in MXA about lowering the oil height/ cc's to make them feel more plush but they dont say if you take it out of the top or the bottom side. From what i understand they are separate.. Can you anyone explain a little more?
The the fork legs off the bike.  Remove the air bleed screw from the fork cap.  Invert the fork leg and allow fluid to drain out of the air bleed hole.  Measure the volume of oil removed. In this fork, 28cc of oil = 20mm reduction in fluid height.  20mm would be a big change.  Drain the same amount out of each leg.
