Rancher low compression
So is it not running at all now or did you just decide to do a compression test on it again? That auto decompression could be in the right spot, releasing pressure on you.
True. Could be anywhere from 75 to about 110 psi. If it's 0psi then I find it hard to believe its rings. they will usually give you at least 25-50 psi even if they are bad.
