carburetor without throttle stop screw?
The throttle stop screw enables the slide to stop and idle. Without it, the common 'fix' is to tighten the cable to hold the slide in position when the throttle is released. However, the slide may move when the bars are moved.
It is obvious you have a bike in need of TLC. You cannot expect it to work correctly until AFTER you resolve all defects.
A good diet will not bring a dead man back.
