Crf50 budget forks
What mods have you done to the rear suspension ? If it's a stock rear end anything with inverted forks is going to make it ride like a chopper. Also note that most head tubes those forks are designed for are longer than the stock crf and will need to be modified.
U can go with an 11" or even 12" rear shock. Or what I did was go with a shock extender from Tbolt USA. It come in two different sizes. I went with the larger one and it raised it about 1.5"-2". But if u used a shock extender U would want to get a BBR stiff spring to put on it because it is still the stick shock. But with most a new shock U might be able to have stuff like rebound adjustment.
I have a set of small inverted forks that are made for a crf 50 style frame with front caliper, stainless line and master cylinder if your interested.
Ok sorry not interested
I will get the bigger rear shock but I was looking at the BBR e6 forks
but it says it has sold out anyone want to sell their BBR forks?
  • 2 weeks later...
