swingarm seals
ok so quick one really ive pressed the bearings in and im about to put in the seals and washers etc i know the washers go in first bu then i have two sets of seals one that is metal rimmed the other is just rubber from what it looks like i just use the metal rimmed ones as the other rubber ones are not on the parts fiche. should i use them both or what?
thanks in advance guys.
this is the rubber seal i dont think i need to use
i should add that im fairly certain that no rubber seals came out when i took out the bearings bu that was about 3 weeks ago and i have been busy since then and cant remember. but of the old parts that i collected they aren't in there
Edited by tumbiri
this is a screen shot of the fiche
8. is the shaft seal bucket
9. is shaft seal the metal one
12. is the stop washer
its possible that the fiche is wrong i just dont want to not put them in and reassemble and have to put them back it etc.
the kit comes with four of these rubber seals btw
i ended up not putting in the rubber seals did some measuring with the micrometer and there was not enough clearance for the seals to fit in as well so i couldent put them in there anyway it does see odd that they were even supplied but oh well.
those seals are a bitch to get to seat in so they go in flush.
