Complete aftermarket plastics ?
Hi , I'm looking for a complete plastics ( new) for a 2013 ktm xcw 200. Most listings don't have 2013 and or don't supply either rear number plates or air box covers. Any experiance here on this.?
You should price out the OEM stuff. It's not that much more expensive and comes with the pre-printed graphics. As someone mentioned you can use the 14 parts, but you also need the air box covers if you go that route and an adapter for the front fender. If you go with the 14 get the 14 number plate unless you're keeping the 13 headlight, then you have some trimming to do to make it fit with the '14 fender. In that case you might want to just keep the 13 fender.
After a simple check with some major plastic's companies, both Cycra and Acerbis offer plastic kits specifically for the 2012-13 XCW's.  You can get a complete kit from Acerbis that includes the airbox/side number plate plastic, or the kit from Cycra that comes without the airbox, and then get an OEM airbox.
Edited by motonack
