Dirt bike oil?
Ok so for Christmas I'm buying the whole family dirt bikes... When I get them I'm going to change the oil in all bikes. Can anyone recommend a good dirt bike oil? Can I get a reliable oil at Walmart? It will be one yamaha 250 one yamaha 125 and a Chinese automatic 50cc for the 6 year old if make an cc makes any difference. Thanks!
Lots of opinions, you did not state if they are 4 stroke or 2. so I will answer both.
4 stroke - Walmart. I use shell rotella in my quad and all my bikes.  I change the oil when it turns dark , depending on conditions this can be 5-15 hrs. Because of my frequent changes I dont feel synthetic or high dollar oem oils are necessary.
2 stroke oil cannot be purchased at Walmart, I get Motul 700 4 liter size from amazon for 52 bucks...costs 25 bucks per liter at the local Cycleger store.
Rocky Mountain ATV (online) is also a good place to start when you are looking for anything
here are the links to everything in my motorcycle bookmarks folder
Motorcycle Shopping
Rocky Mountain ATV/MC Dirt Bike Parts & Motocross Gear |
Cycle Gear - Motorcycle Apparel, Parts and Accessories
MotoSport
Motorcycle Superstore
BTO Sports
MotocrossGiant
Pit Posse
CRF's Only - Your source for Honda CRF information, performance parts, and accessories
MOTOWORLDRACING.COM EL CAJON, CA 1 (888) 929-9111
Welcome to Worldwide Powersports -
Extreme Supply
Motocross & ATV Gear - RevZilla
Chaparral Motorsports
Dennis Kirk Inc Chrome Addiction Motocross Gear RidersDiscount.com
Helmet City
MOTORCYCLECLOSEOUTS.COM
Service Honda Home of the CR500AF 500AF 500AFX Junior-X - Honda Motorcycle Parts
GOFASTERS gasserparts.com
Shop For Mens - Motocross Apparel and Parts, Shop For Mens at Bob's Cycle Motorcycle Radiators | Motorcycle Radiators Repairs | Motorcycle Radiators OEM Parts, Hoses and Radiator Caps | Myler's Radiators
@ Powersport Junkie, You'll Find the Lowest Price Guaranteed on Dirt Bike Parts, OEM Dirt Bike Parts, ATV parts, UTV parts, Harley Parts, Cruiser Parts, Dirt Bikes in Las Vegas
United Distributing LLC Motorcycle Closeouts
Bearing Connections
MAINT
Sudco International - Carburetors and Induction page 2 Jetting Full Gear Ratio Chart (pdf) - JT Sprockets Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power back bleed brakes
TORQUE TOOLS AND TORQUE PRINCIPLES AND PROCEDURES -cont
GasGas Parts Crossover
Chain Wear
Look for the Products that Carry the API Quality Marks
Gear Ratio Chart | ProTaper
Sprocket Calculator - the easy motorcycle sprocket and chain calculator
Motorcycle Tire School
How to Compression Test a 2 Stroke or 4 Stroke Dirt Bike's Engine
carbs101.pdf (application/pdf Object)
Coolant Mix and Overheating
ThumperFaq: 4-Stroke Oil
Baja NO PINCH Tire Tool
ThumperTalk - My Account Skull Creek - Private - Texas Offroad Network Forums
TWT Forums - Powered by vBulletin
…because it's a bad ass plan Trail Riders of Houston
ThumperTalk Trivia Challenge - Daily Trivia Game
VTR 1000F parts and accessories undertail rear hugger frame protectors
Tire Changing Stands SpudBilt > Home
Cinchitdown.com | Products
ktm-parts.com: GasGas Electric Start Conversion Kit
CRF250X Introduction
TPWD: Where to Buy a Texas OHV Decal - Off Highway Vehicle Program
Zac Speed Exotec RP-3 Protectors
Homemade Dirt bike stuff! - ThumperTalk - Page 5
Edited by Jakeblues
You will find a opinion supporting just about anything on here. Let me share mine. Two strokes do not pump oil up to the top end so it is recommended to run 80 w gear oil. The oil you mix in the fuel lubes the top end. Four strokes do pump the oil up so it is recommended to run a lighter oil 10-40w or something like that. I do not have a strong enough opinion about any oil to recommend it over the others but I run either rotella or golden spectro.
In actuality they are about the exact same weight. Just a different grading scale. Kinda like saying 2.54 cm is longer than 1 inch because the numbers are higher.
ok let's agree the w stands for something. To the op. You will likely find if you open the manual to the bikes you purchase the four strokes will call for a oil that has a 10-40W "rating" or there about and the two stroke will probably call for a "rating" of oil near 80w. By the way most people that are not rocket scientist refer to the w as weight even though the oils actually weight the same. Viscosity is the true meaning of those "ratings".
Happy now Bill I have not lead this person to believe a quart of oil weighs different amounts based on viscosity. You have saved him from my original misleading post.
Edited by motojunkiedan
Look, no offense to anybody and thank you very much to the helpful responses ive received, and to the rest of you, no I do not have a great understanding of dirt bike motors so let's try and keep this forum knowledgeable and helpful for those who come here to learn and understand things. Now, let's start off with the automatic 50cc that will be ridden by a 6 year old. It's a little Chinese ssr, and the instruction manual is completely useless (those who have bought these bikes probably understand). It does not tell me anything as far as oil to mix with gas or any other oil that the bike would take such as gear oil or whatever it may take. The next bike is a 04' yamaha wr125 4 stroke, it will be ridden by a 28 year old mother with zero riding experience and she will doubtfully ever push the bike very hard. The next bike will be a 03' yamaha wr250 4 stroke, this will be my bike. I haven't ridden dirt bikes in 8-10 years however I've ridden Harleys almost daily ever since. I have plenty of riding experience and will more often than not try and find out what my bike can do. Hopes this info helps the understanding and helpful folks out there. Thanks!
