Drz Talon hub tabs for speedo drive bent
Happy Holidays everyone,
This is my first post (clap clap) 🙂
I've got a drz400s with SM wheels/Talon Hubs.
Hub Tabs are a little bent as the speedo drive will not hook up flush like it normally should. Looks like a tab ripped open a little crap in the drive as well. What are my options? Buy Vector and Dremel tabs off then replace with Speedo spacer? All help is greatly appreciated. Thank you so much and happy riding.
I don't see the problem.  The hub looks OK.  The tabs just need a little clean up.  The speedo drive needs to be taken apart and the drive tabs on the gear straightened out.  That should provide a good positive connection.  The problem occurred because the speedo drive was not lined up correctly when the wheel was installed at some point and it bent the tabs.
  • 1 month later...
