Have a simple question..Draining float bowl related
Do you drain the gas from the float bowl by loosening the small Allen bolt next to my finger? Then letting it drain down the purple hose that is connected to it. Or by the large nut (which you can also see in the pic) that sits under the float bowl? I'm guessing it's the small Allen as the large nut is for access to the main jet..
I couldn't find an answer to this after searching.. Would appreciate any help!
Edited by NW_drZ
