Yz 250 tranny bearings
How hard is it to get em out?
I've replaced main bearings before on the 450. Used the warm oil in a pan and soak trick while freezing new set. Worked like a charm.
The mains were easy because then can be coaxed from outside of the case. The trans bearings in there look as if they need to be pried out.
Oh and I lost the dang ole woodruff key. No idea how. Thought flywheel popped off to easy. Maybe it wasn't there.
  • 2 months later...
