New-to-me bike
Had to fix a few things, including the kick start lever we broke while checking it out. Clutch plates were stuck together. Timing is off as it runs backwards every other start. Relatively easy fix. Assorted bolts stripped out. Swing arm had the 'my Sherco rear sprocket bolts came loose disease'. Good find but the average person would have steered away from it because of the 'problems'.
Edited by DR.billZ
I've been dying to come across any trials bike that needed a little work like that. If you don't mind, how much did you find it for?
