Water in dirt bike
Remove the air filter and clean it. If there is dirt  behind the air cleaner in the boot, you will need to pull the carb and clean it
Remove/replace the oil at least two more times
Re-route your carb breather hoses up under the tank
Clear your crankase vent hose plug, if it has one
Put in a new plug.
