74 mx 125 carb size
The dt 125 has a 24mm carburetor with a 140 main jet and a 25 pilot jet.It should work,you probably will gain in the mid-range and loose a little in the top-end.37$ is pretty cheap,not much to loose if it doesn't work.
awesome! I'm not going to race it. Just something to restore and ride around in the pits
Hopefully your $37 carb will be able to have the jets replaced. On some of those knock off Chinese carbs Mikuni jets won't work. A 1990's later model YZ 80 carb will fit and can be rejetted. Good luck.
yeah I just got it in the mail today.... Totally won't work...ImageUploadedByThumper Talk1419718838.627161.jpgImageUploadedByThumper Talk1419718862.271662.jpg
you need a vm28 spigot mount - you could go as big as 32 or 34, but the carb will hit the pipe, and you'll need to do some modifications.... i have one with a 34 on it..
I'm just going to send it back. I'd like to keep it as close to stock as I can
