sm wheels to mx wheels front brake problem
I am putting on a set of offroad wheels onto my 2002 drz 400 it came with sm wheels but the front brake carrier does not fit correctly it doesn't go deep enough onto the disc and I cant find an original any help please
Remove the caliper spacer bracket! If your bike is an 02 then it didn't come stock with SM wheels and you are probably running a 320mm brake rotor with caliper relocating bracket. There is nothing wrong doing as noted above but this way you don't need to buy a new $$$ brake  rotor.
  • 3 weeks later...
