Turning upper front fork tube 180 degrees
The air chamber is only retained by a circuit, so you should be able to let all the air out of the fork, depress the inner part of the fork cap, turn it to the best position and then refill with air. You don't need to loosen the fork clamps
Circlip not circuit. .....auto correct!!
