Kawi question 1991 kx80
not sure, but a kx 100 is more or less a bored out 80.
http://www.amazon.ca/Kawasaki-91-00-01-10-KX100-89-09/dp/1599693356
other things to look for are is the connecting rod the same length, and is the bottom end the same.
as in just because they share the same manual does not ensure that they are identical, they possibly could just have the exact same design but the 100 is slightly different dimensions.
someone else should know if its a direct bolt on.
if nobody knows, pick up a beat up one off ebay cheap and give it a try when your re building your current top end.
