carb not returning
Remove the cables from the carb and see if you turn the actuating arm that the carb returns properly , should have good resistance turning it and it should spring back , then you will know if the problem is with the cables or carb itself
Try releasing the adjusters on the cables. You may be way too tight.
make sure the throttle tube is not shoved up against the end of the handle bar.
use only wd 40 or similar lube in the tube, no grease.
Double check the cable routing , make sure no kinks or gas tank Is pushing on of them against the frame etc.
that's about it.
Al
the cables have a certain way they go. near the upper mount of the radiator, thru the frame near that area besides the fuel tank but not on the resting spots and down t the carb or throttle body. The easy way to check them is to pull on them a bit an make sure they are not stuck in that area.
Al
