Bolt sizes on yamaha yz250f 2001-2002
If you look up the yamaha part number, you can decipher the bolt size from the part number. Post up the part number for it and I can probably tell you what it is. For example, look at the part number and look to the middle section of the number _ _-_ _ _ _ _ - _ _. Lets say that the middle section has the numbers XX-0860X-XX. The 08 will generally be the diameter of the bolt (8mm) and the 60 will generally be the length (60mm). Hope this helps.
