Kxf 250 2007, back firing
  • 2 weeks later...
07's are carb...providing you have no air leaks Try turning the fuel screw out a 1/4 turn at a time until no decel pop. If you have to turn it out more than 3 full turns from all the way in. Then you need to re jet. My 07 stopped popping with one 1/4 turn. Now would be good time to buy a long fuel screw so you can easily make this adjustment if your carb doesn't already have one.
Try adjusting the fuel screw first a 1/4 turn at a time , if that doesnt work then clean the carb especially the pilot circuit and pilot jet, fit a aftermarket fuel screw.
If that still doesnt work then you need to check for air leaks and also check the o ring on the slide plate, as it wears and lets air through.
Depending on the number of hours on the bike it may need a new slide plate or even a new carb.
At 600 hours with the same issues i had to replace the carb as it was worn too much around the slide.
  • 1 month later...
