2007 cr125 which crankcase bolts go where?
It's easy, just drop the bolt in the hole. Each bolt will have about the same shank length sticking out of the hole when all of the bolts are in the right holes. That's if the cases are already snug. Or use a hole depth gauge. You may have to switch around a few bolts before you figure it out when you really snug up the case halves. Does that help? A maint. Manual will tell you exactly which bolt goes where. Don't over torque....
Edited by dirt_e_rider
