Another Knocking TTR 125
2001 TTR with fairly low hours on it.
It developed this knocking sound recently.  Valves are in adjustment, and the cam chain tensioner seems to be working properly.
It is a bit hard to start, but kicks over very easily.  Honestly, my other son's XR 100R is "stiffer" to kick over.
Here is a video of the sound.  I suspect that it may be a rod knock of some sort, but do not want to split the cases if I do not have to.  BTW, it seems to rattle the same regardless of type of fuel used.  It's currently running fresh race gas and still rattles.
Thanks for the help
Get a mechanics stephoscope or use a screwdriver to your ear to pin point the area the sound is coming from.
From the bottom. Likely its the big end rod bearing. From to cylinder: The small end rod bearing, a valve is tapping the piston or you have piston slap. From the top: your valves are not correctly adjusted or your cam chain is is loose. What have you done to change things that may be a contributing cause? Nothing = motor wear.
Regards,
Paul
Edited by pcnsd
