2002 CR250 Total Refresh
Considering doing a total refresh for my 02 CR250. The bike is 12 years old at this point.
I just wanted some input on what I've priced out so far.
Ok! So I need a new top end. Getting my cylinder replated at Millenium. Purchasing OEM piston, wrist pin, bearing, clips.
Purchasing bearings for the bike. (steering head, both wheels, shock, linkage, swingarm.)
Purchasing fork rebuild kit + tools to do it the CORRECT way + oil.
purchasing shock rebuild kit w/ shock spanner wrench.
Purchasing OEM radiator shrouds for a fresh look.
Replacing my cracked clutch cover with a boyeson clutch cover.
Purchasing new brake pads + changing brake fluid + installing steel lines
Didn't include it in the cart, but new sprockets and chain.
TOTAL PRICE ~$1000.
Questions:
Is there ANYTHING unreasonable or not needed for a genuine refresh here?
Is there ANYTHING I forgot to include for a refresh here? (clutch and bottom end in the motor are fine.)
Is this PRICE reasonable? Can I save money somewhere else? (motosport.com) I was going to use their price match guarantee and get them to match prices from partzilla.
Any advice you want to give me? This is a big purchase.
  BikeMaster Fork Cap Wrench
46mm50mm
In Stock
$25.99
  Bel-ray Fork Oil
1 Liter 5W
In Stock
HAZARDOUS ITEM - Must Ship Ground
$14.99
Motion Pro Fork Seal Bullets
Single 47mm
In Stock
 $4.99
Ratio Rite Measuring Cup
In Stock
  $5.99
BikeMaster Shock Spanner Wrench
In Stock
      $8.99
BEARING, CONNECTING ROD SMALLE
FITS: 2002 Honda CR250
91015-KZ3-003
In Stock
      $12.91
CLIP, PISTON PIN (1.2X18)
90601-430-000
In Stock
      $4.38
Boyesen Clutch Cover
FITS: 2002 HONDA CR250
Black
Earns $5 in Fast Cash!
In Stock
      $89.99
JOINT, EX. PIPE
18351-KZ3-L20
In Stock
      $27.87
PAD SET, FR.
45105-MY6-415
In Stock
      $35.18
PAD SET, RR.
06435-KZ4-J41
In Stock
      $29.87
PIN, PISTON
13111-KSK-730
In Stock
      $12.53
PISTON B
13102-KSK-670
In Stock
      $79.12
  RING SET, PISTON (STD)
13011-KZ3-306
In Stock
      $39.27
  Pivot Works Steering Stem Bearing Kit
In Stock
      $44.99
  Pivot Works Swing Arm / Shock / Linkage Bearing Combo
Linkage: Linkage/Shock Bearing Kit
Swingarm: Swing Arm Bearing Kit
Shock: Shock Bearing Kit
In Stock
      $179.99
  Pivot Works Wheel Bearing Kit
Front
In Stock
      $29.99
Rear
In Stock
      $24.99
Next Shipment
Expected to ship on Thursday, January 8th
    Quantity Each Total
Pivot Works Fork Seal & Bushing Kit
Available - Requires 2-4 Business Days to Ship from Our Warehouse
      $74.99
Pivot Works Shock Repair Kit
Available - Requires 5-7 Business Days to Ship from Our Warehouse
      $89.99
  SHROUD SET, L. RADIATOR (TYPE1
FITS: 2003 Honda CR250
19072-KZ3-J50ZA
Expected to Ship in 4-7 Days
      $59.90
SHROUD SET, R. RADIATOR (TYPE1
19071-KZ3-J50ZA
      $59.90
Edited by Mikepagjr
Honda East Toledo has some of the best prices I have seen on oem honda parts.
The fork seal kit....stick with oem. Its very good quality for cheaper than the pivotworks kit. Get some fork seal grease. Pro circuit, race tech both offer it and it really helps the seals.
Fork oil...In my experience, the bel ray fork oil has always seemed mediocre. I like the maxima racing fork oil. You will need 2 quarts.
You don't necessarily need the fork seal bullets. A plastic bag with a little fork oil or seal grease works well too. Will it be easier using the fork seal bullets. .probably, but not required.
Exhaust joint...is that the piece that connects the exhaust pipe to the cylinder head? If so, get the pro circuit or boyesen version. Its a lot more robust.
Radiator shrouds....unless you are dead set on the oem ones, you can probably get some from Acerbis or some other company cheaper.
  • 11 months later...
Send your cylinder to US Chrome instead of Millenium. Millenium is run by former US Chrome employees who poorly copied their formula and opened shop down the street. I have heard of multiple people having problems with their Millenium cylinders, but to this day haven't heard of any problems with US Chrome. Dish out the extra $20- it will be worth it.
DSCF12521.JPGDSCF12521.JPGdidn't try to put 2 pics crack is at top of bridge, look very close at the exhaust port bridge in the cylinder & make sure its not cracked, I also own an 02 they are known to crack. for an extra bit of $$ u can get a new cylinder & it comes with power valve installed. I think I paid 369.00 for mine last year @dallas Honda. I would replace the crank seals witch can be done externally, you need a flywheel puller to change seals, 15.00 @ motosport.
how do you like that 02,I think they are one of the best cr250's, handling is awesome feels light. good luck with your build
Edited by mxsteve1968
