I need help:(
And if you have a Honda or Kawasaki with the rubber bar mount inserts, just grab the front wheel between your knees and give the bar a yank back in the direction required to straighten them up.
Naahhh, if you ride long enough with messed up bars, you'll get used to it and straight bars will feel weird!!
  • Like 3
Are the bars actually bent or just out of whack. Cause if they are just crooked you can do that vvvvvvv there is actually a video on youtube on how to do it it is on a street bike but still the same concept:
If your bars are bent you're gonna be stuck buying new ones. If the front end is out of alignment put in on a stand, loosen triple clamp and realign. Do not over tighten.
