SSR 125 Carb problem
Need some help. I took the carb off of my bike to make some adjustments. Now when I put the top of the carb back on, I can push the carb slide all the way down. When I pull the throttle the slide comes up but doesn't go all the way back down.. The throttle only close half way by itself. What should I do/\?
Is spring holding needle down correctly if spring is in correctly the needle might be hanging up if you have to push it down ,it should slide down easy and if it does go all the wa down its not cable adjustment,it could be that the throttle cable is popping out at carb or handlebars causing it to not let slide drop.Its something simple you missed,if need be take carb off and install slide and cable and see if it works as it should,There is a few things from bent needle to dirt on slide, to clip off the needle!!Good luck ps pull up breakdown of carb on laptop and look at slide,needle keeper spring etc.
