Hotcams stage 2 - which one?
There seems to be two different stage 2 hotcams listed for the 2010+ crf250.  1158-2, 1265-2.  What's up with this?
It looks like the 1158 may be an older version (it's listed only for 2010-14)?   The 1158 looks to have more lift/less duration, and the 1265 is less lift/more duration.
1158: http://www.hotcamsinc.com/ProductInfo.aspx?item_id=94
1265: http://www.hotcamsinc.com/ProductInfo.aspx?item_id=6760
Any suggestions on which would work best on stock head?
Check out the hot cams support / faq section. The difference is that one is a standard version and the other is a gold with the lift and duration differences that you listed. The gold is meant for more aggressive or higher hp builds from what I gather. In the CRF250, some of the gold cam models require you to check head clearance because of variations in Honda head manufacture.
