Why year wheels interchange?
03- up from any Ktm big bike will fit. They changed the color of hubs through the years. I think the billet hubs started in 07-08. Not 100% on that. 2013 they changed the rear axle size. Which will still fit if you changes spacers etc.
Also, DRZ S wheel sets should work.  I bolted a rear wheel on without any mods except a larger sprocket and my 20 mm axle front wheel bolted on after buying the 20 mm KTM axle, nut, and KTM 20 mm to 26 mm kit (in hardparts book) while modifying the right spacer for the DRZ S front wheel and using the new spacer that came with the 20 to 26 mm kit.  Use common sense and try this at you own risk.  My bike is a 15 300 XC-W 6 days.  I plan on running trials tires on my spare set.
