Crf/xr100 motor rebuild
So I got the engine back together. All timing is right. Didn't touch cam adjuster. All timing should be good. All lined up but the cam doesn't clear the valves. It gets stuck under it. Pls help! I posted a pic of the issue. I have the valve cover and top off the motor to show you it's in the top part and valves. It looks like the rappers aren't clearing the valves. Causing the cam to get stuck cause there's no where for the valves to go. They're loosened all the way. It's the arms that get caught. ImageUploadedByThumper Talk1419980936.084283.jpgImageUploadedByThumper Talk1419980957.877894.jpgImageUploadedByThumper Talk1419980775.996806.jpgImageUploadedByThumper Talk1419980848.756401.jpg
