Can't get the motor we just rebiult to start
Up to now you've determined that fuel is reaching the combustion champer (plug is wet)
and getting a good spark at the plug tip. How about enough air, try setting the idle screw a bit higher.
As above, is the piston installed in the proper direction?
Reed valves in good condition and properly sealing all the way around each petal?
Was the stator assembly removed during disassembly? Perhaps ignition timing is off.
Also, is that RTV gasket maker is see used in place of the gaskets for the water pump and side cover?
Edited by mlatour
