06 crf250r. bogging, popping new cam
So I've got a 06 crf250r that is having a popping issue when letting off the gas and it also bogs when im in third coming out of a turn. Had the head rebuilt by fastheads a year ago and now I want to put a new cam in it. I dont know if I should do a stage 1 or 2 with my setup.everything is stock.
So I was hoping to get some insight on what to do
ive heard the bogging could be solved by a leak jet or a boyesen quick shot set up. I dont know what the popping from letting off gas could be and I know this isnt the right spot for a cam shaft question but was hoping someone will know what the differences are in a stage one and two I understand the two will be bigger but unsure if it will work on my bike. If I can use the stage two without alerting or adding more to the bike then ill do that one..
thank you for reading!
