valvoline 2t oil in 03 rm250?
If I remember correctly Valvoline has a racing 2t motorcycle premix. I use to buy it by the case at autozone, good stuff. Autozone use to carry a moble 1 2t a was also good. Havent seen it in a while.
Are you asking about pre-mix oil, or tranny oil?
If you're asking about premix oil, any two-stroke  oil that has either API TC, JASO FD or ISO-L-EGD rating is acceptable for our engines. API-TWC-3 oils are not.
If you're asking about tranny oil, any quality 10W-30/10W-40 engine oil is fine, or you can run 80-85W gear oil, or (my preference) Type F ATF.
  • 3 weeks later...
