cr150f mods with xr200 parts
Friends son has a stock 150f,around 09 vintage. I have boxes of xr185/200 engine,cams,big bore pistons,carbs,hop up parts just sitting around. Not catalogged,but sure I can figure out what I have. Thought we might give it a little boost! Would a 200 cylinder,head,and cam bolt on,or some combination,and would it be an upgrade? I realize bigger bore is good,but do 200 heads flow better than the 150 heads? I don't expect it to be a fire breather,but its fun to experiment with them,and wouldn't cost me much out of pocket. Thought Rude and Chuck might have some input,dont want to go up a dead end street,rather ask the experts! Thanks
Some baseline data:
Model             Model Code  Bore    Stroke  Displ     CR
CRF150F                               57.3      57.8     149        9.5
CRF230F              ME09        65.5      66.2    223.1      9:1
XR185                  ME02        63         57.8     180.2     10.0
XR200/200R        ME02/4/5   65.5      57.8     194.8     10.0
A XR200R engine has peak power close to a CRF230F, but not as much bottom end.
The XR cams are the most aggressive of the two valve cams.
Simple solution: Buy a XR200R and put the engine and electrical system into the 150F.
