need the "triangle" suspension knuckle piece. Mine is jacked up. Same as 250R ?
At some point in the past, I hammered my 04 250X down on a rock and smashed the triangle shaped knuckle piece of the suspension linkage.  I went to put in new seals and the seals will not go in and stay.  So I need to get a new one of those that will fit my 04 250X.    Will the ones off of a 250R fit my bike ?
The R model will fit but it is not correct, you will notice a letter/number code cast onto the knuckle which must match the code on the linkage arms, these are different depending upon your year model so use caution when buying used!
Edited by chopper61
