beringer tech question
hi. i have purchased the brembo radial adapter for the drz400sm and I was wondering if I would be able to use other calipers like the Beringer 100mm radial caliper on the adapater that is made for 100mm. I already have the Brembo caliper and it looks like it would be compatible aside from the fact that the back of the caliper and a notch in between the pots are shaved down for clerance to the rim and mounting bolt.
just that i cant find the rotor i want from brembo. and the beringer suits my style a bit more
also what is the cross reference on bikes that use the brembo from the factory thank you very much.
Edited by HooliganNation
KTM's use Brembo and Beringer. I'm not 100% positive but the adapter should work.
