1997 XR400R suspension differences
Managed to get both the Aus(pdf) and USA (hard copy) XR400R owners manuals both for 1997.
Besides electrical difference based on Aus model haveing turn signals
 ect the suspension adjusting sections were different.
Front oil lever
USA 97-130mm
stock 100mm
Aus 87-129 mm
stock 116mm
Front rebound damping
USA
at least 12 positions
4 clicks per turn
stock position 5 clicks ccw
Aus
6 clicks per turn
stock position 3 clicks ccw
Front compression damping
USA
at least 20 positions
4 clicks per turn
stock position 14 clicks ccw
Aus
at least 16 positions
4 clicks per turn
stock position 8 clicks ccw
Rear spring length
USA
205.3 to 217.3
1.5 mm or 15.0kg per turn
stock 212.3
Aus
205.3 to 216.3
1.5 mm or 15.0KG per turn
stock 212.3mm
Rear rebound damping
USA
4 clicks per turn
stock position 4 clicks ccw
Aus
4 clicks per turn
stock position 10 clicks ccw
Rear compression damping
USA
at least 18 positions
6 clicks per turn
stock position 13 clicks ccw
Aus
6 clicks per turn
stock position 12 clicks ccw
Are the suspension components different or just the stock settings based on Japan assumed rider weight difference?
