Trail tech Vapor indicator dash wiring fiasco: neutral light always on!
Newb to the forum here. I've searched through the forum and I've seen many other posts with this same issue, but no recent ones, and no conclusive answers to the issue of the neutral indicator always staying on when in gear. Any help would be appreciated. Thanks!
Found this doing some googling...
"all I did to set up the neutral was to just put the wire right into the old unit that the stock cluster plugs into. It works fine and I've never had any problems, just get your users manual out and match the light you want to work with the corresponding output from the stock gauge cluster."
