DR-Z400E, DR-Z400S can you tell difference in pictures?
Is it possible to tell the difference between a DR-Z400E and a DR-Z400S just by looking at pictures? What are the distinguishing factors? I've seen some bikes listed as DR-Z400S with aftermarket lights and other parts that look like they could be an E.
Here's an example.
http://imgur.com/548Lkwb,57RGWBY#1
http://imgur.com/548Lkwb,57RGWBY#2
This is listed as a S model, but I don't see any rear lights and it only has one mirror. What else should I be looking for?
Here's an example.
E model has a plastic tank, S has metal. E model has the FCR carb which is pretty easy to see right away, the S has the smaller Mikuni. The E doesn't have a speedo, just an hour meter......
Here's an example.
i usually look for the subframe. i haven't seen an E with and S/SM subframe on it yet. if it's an S/SM with the frame hacked off it will usually have other dumb 'mods' that tell about it's maintenance or lack thereof, and make me look elsewhere for a reliable bike.
Definitely an S, the front turn signals are still on it, passenger pegs, speedo cable, metal tank, mirror, and license plate, that I can see. I wonder if the owner was doing a wheelie and it went over backwards possibly tearing off the back lights. Or maybe he just wasn't very good at the mod thing.
Here's an example.
it has a helmet lock, which means it has a full subframe.. = s model
Except in SA and Oz, there was an E model, but with an S sub frame and speedo. It still had all the good stuff, plastic tank, cam, exhaust, compression ratio, carb...
