Don't ground accessories to steering stem head
Thought that I should post this because I came across it on my bike as I'm rewiring
Previous owner had installed a horn kit and ran the ground to the front fork assembly. This seems harmless (and maybe for the short term )
The problem is the bearings for your steering/fork bearings become the ground circuit for accessory and could be effected.
With more and more  threads about adding electrical components to the handlebars....Its important to remember ...no current thu a bearing  (run your ground circuit to the frame or better yet to the battery)
Probably not a big deal.  I did it for  years with out knowing better.  In practice though, it is not the right way.  The easiest solution if you've already have done this is to run a ground from the steering head to the frame.  This will avoid an arc through the bearings and ruining the harden surface.
I totally agree with original post.
