Coolant change
I've got Drz 400E and just changed coolant and I can't find water neck air bleed do the E model not have them?
With the radiator cap off and the bike on side stand.
Start and idle without the radiator cap, most any air in system will escape.
Top up, install radiator cap, ride.
Check when cold, top up radiator and or coolant overflow if needed.
Like the oil, inspect/check regularly.
Tip the bike about 30/45 deg right and left with the cap off, that will burp out the air.
Ok cheers aslong as there is no air bleed screw on the neck I think I'm good to go :-)
