Drz400sm jetting issue
hey guys i just installed the jd jet kit 3x3 mod have a yoshi rs2 full system i live in australia on sea level installed 25 pilot 160 main blue needle on the 4th clip 2 1/2 turns on the extended fuel mixture screw and when i get to just over half throttle i get nuffin more we did have too adjust the throttle cable bodys though could it just be that ? any idea's cheers
Make sure the slide diaphram isn't pinched or leaking air
the clips broke on he old one was ordered a new one and put it
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
