2006 LTZ400 head on 2000 DRZ400E?
I need to find a new cylinder head for my 2000 DRZ400E because of a broken cam cap, can anyone tell me if a 2006 LTZ400 head will fit it without modification? What concerns are there between different years and models of the DRZ and LTZ? Thank you
It works fine. I have one on one of my Drzs.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
