Brown Coolant!
i just got my bike back from having the waterpump rebuilt,i noticed that the cooalnt is kinda brown,i read somewhere that it indicates a blown head gasket,but theirs no air bubbles in the coolant when the bike is running...any help?
Is there any corn or peanuts in it?
Did the shop put in new coolant?
Your invoice should say so.
Your options are:
Drain the coolant,
Fill with distilled water,
Run the engine for a minute
refill with 50/50 antifreeze and distilled water, or a coolant mix.
Distilled water is available at Walmart for $0.60-0.70/gallon, one gallon is more than enough.
Any antifreeze is OK as long as it doesn't contain silicates, I buy at Walmart but a local Honda dealer will also have suitable antifreeze or coolant mix.
Change once a year.
autozone branded coolant also doesn't have silicates
Ok than guys I'll try that,just wondering if using rain water is fine as it the same as distiller water
No, do not use rain water. Buy a gallon of "distilled" water. Rain water can have all sorts of contaminants in it and the ph level will be low = acidic. Edited by Eddie8v
ok thanks......I phoned the shop and they said I must bring it in,anyway I'm not going to,I've read somewhere that the incorrect mixture of coolant and water can cause it to go brown
you can buy it already mixed
Ok,will check ,anyway I drained it and there was a slight brown in it,much less worse than I expected.
I wouldn't be worried about it if it was just a slight brown hue to it. Just fill it up and ride it.
Now that's what I'd like to hear!
Not EVERYTIME I ask a question like "slight bog on landing" people go "just do a full rebuild including clutch'"
was just thinking considering you just got your bike back from the shop... i'd say the most likely explanation for the browness was they used old  coolant they had put aside
not a huge deal. change it for 4$ and keep an eye on it. if it happens again then investigate.
dextrol pre mixed at wal mart is 12$ for 4 liters.   or 15$ for for the concentrated stuff + a gallon of distilled water for 1$ gets ya 6-8 liters.
how old is this current fluid?
Edited by coryf89
also... you paid to have your water pump replaced????? thats a 20 min job and 30$ in parts... what did they charge you?
I did the water and oil seal,and bearing....alltogether it came to $150 in your money,stuff is expensive in South Africa....
why wouldnt you do it yourself and order the parts off ebay for $40 USD???  its literally one of the easiest things to replace.
Edited by coryf89
1.we don't have eBay here like you do
2.i don't have a seal puller and bearing puller,the parts came to about $55
Also is it fine if I use car antifreeze in my radiator?
seal puller and bearing puller.... come onnnnn.
the bearing and seal are garbage anyways, pound them out from the back with a flathead screw driver and be done with it.  why do you need to carefully pull out a 8$ damaged bearing and seal with a 50$ tool thats going in the garbage anyways???   lightly tap the new ones in with a large socket the outside diameter of the bearing race and dome grease and done. look it up on youtube....
ive used car antifreeze (prestone from walmart) for 7 years now with no problems.  400 engine hours, probably changed it 3 or 4 times. cheap chinese oversize rads.  my bike is always in the mud and water crossing rivers. no problem whatsoever.
Edited by coryf89
  • Similar Content
    • By Brady The Honda Guy
      I recently put a newer style fender and plate on my 2007 crf250r. I just had to drill a couple holes in the fender and I used some washer on the back bolts to angle the fender up a bit. Since the original plate mounted with one bolt in the center and the newer styles mount with two bolts, I had to make a custom bracket. Message me if you need dimensions for this bracket. New style is in my cover photo, stock is in my profile picture.
      So I can get a 1986 cr250 motor for a good price and I also know a guy that has a 2005 crf250r that needs work. I have the idea of just swapping motors. Would this motor fit in the newer frame?
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By DirtRider250x
      Hi all,
      My main question is how can I make my 250r more reliable. I have owned it for 2 years and it was spent about 1 year in the shed probably needing new valves and piston rings (i have been putting it off) Will steel valves last longer and work well in the engine? Also, what are your thoughts of me selling it and buying something newer? is it worth it?
