Cannot Kick 04 CRF250
Bike will push start and runs fine but it's impossible to kick. With a push start, the bike runs and rides like normal. No clutch issues or shifting issues. I can force the kick starter down but it's a strain. I've pulled the outer case and the starter setup is correct. When I pull the clutch and basket the kicker is easily moved, but with the clutch assembly in place the problem comes back. I picked this bike up cheap as a project but I'm at a loss really as to what's going on. I will rebuild the entire bottom end if I have to but I dont want to miss something simple just because I'm not looking in the right place. Any advice is appreciated.
jeff
Having a tough time with mine as well.
However with all the people I spoke to i found out that your best bet is to start with a carb clean.
Clean well with carb cleaner and make sure to call your local dealer to have them order a new o ring set for it, you need to make sure they're no air leaks.
If you have time while your bikes already apart, check valve clearance and buy yourself a shim kit for around $70-90 and feeler gauge. A lot of youtube videos can help explain how you find the right shim with giving you formulas etc...
Hope this helps .
If you cant kick it through on the kickstart somethings is really wrong. Either the kicker is binding somewhere, or you have a main bearing or conrod bearing that is seizing up. I would remove the kickstart idler gear and then try and turn the engine over to see if it frees up.
Why the hell do newbies keep reviving these old posts......
